In that case the keyboard player chooses the voice not the engineers.
Same with the live performance using drum triggers. In the studio, it could be either the drummer or the engineer. But, I gotta tell you, as a producer I have changed many a keyboard sound from what the key player used. Just to get things to fit in the mix better.
Well I was directing this to home recording particularly. There were some good statements made and they do make sense. It feels like even though the drummer is playing the notes they aren't neccesarily making the sound.
Right, just like a key player.
Most of the statements I've heard in the triggers deffense were compensation for bad drum technique. It may be miss use but It seems like an easy way out for some people.
It's not an easy way out for the drummer, he is still playing.
Have a problem EQ'n that bass or snare?
Use drumagog.
If you can't EQ, you aren't going to get much out of Drumagog. The samples that you get won't magically fit perfectly into your mix. You still have to EQ them. It can help you when the drummer just has the wrong snare for the type of song he is playing.... But that isn't talent shortcoming on eith the drummer or engineers part, it's normally a money issue. (How many snares, or entire kits, can the drummer afford to own?)
I have heard alot of great recordings without triggers and fast double bass lines.
Are you sure?
It seems like a let down for me when I hear a decent recorded snare but then I read up on what the following thread says was used and it usually comes down to triggers.
There is a snare sample layered over the real snare on the Metallica black album. They didn't do that because they didn't have the money, time, equipment or talent to do it right. They did it because it enhanced the sound and got it closer to what it needed to be in the mix.
I guess it could be used as cheating but not always. You're right though when I think about what you said It can be helpful but personally it bothers me because I'm not playing a cheap kit.
Is someone forcing trigger on you?
It is like buying a mesa boogie rec guitar amp and the recording engineer plugs you into a tiny little digitech pedal because he can't mic your amp.
If you need a more processed guitar sound (for some reason) the boogie is not going to cut it. The digitech might be the right tool for the job. If you need a more Marshally or Fendery tone, a Pod might do it for you for those parts because the Boogie will be useless for that. It's all about context. A Fender Priceton is a great amp, but it's useless for Nu-metal, likewise a dual rec is useless for country.
I agree with you on the consitency/dynamics but im still a bit iffy on the use for an "easy way out."
Easy way out of what?
The connection I was trying to make with drum machines is in the samples they use partiularly the default generic samples. Go to soundclick.com and browse a bit im sure in twenty minutes you will hear the same exact samples used over and over.
I don't know anyone that triggers general midi drum sounds from their kit. There are several drum brains that have hundreds of sounds to choose from. The Alesis DM5 sounds are not the same as the Ddrum module sounds which are not the same as
the Roland Vdrum sounds, etc....
Do professionals record a bass/snare drum hit and put that into the form of a sample? I'm a bit of a n00b on this topic but if everyone is using these triggers where are the samples comming from, theyre own recorded samples or a giant library somewhere?
Well, Drumagog comes with almost 4 gig of samples (a good portion of which I made), and there are sample libraries that you can buy for Drumagog. You can also sample your own kit and use those for samples. You can also borrow your buddy's really nice snare and sample that.
Another cool thing about sampling is that you can sample the drum under ideal conditions. Brand new head, pefectly in tune, multiple mics on one drum with no bleed, use an LDC (which normally you couldn't because it would be in the way of a drummer behind the kit, etc...
