Drum Sampling
  • Thread starter Thread starter DonaldChang
D
DonaldChang
Banned
I've recently gotten into drum-sampling and I don't know which depth and rate i should be sampling @?16 bit 44.1 khz or 24 bit 48 khz :confused: ?
I know 24 bit is what alot of people use to mix @...from what i understand more bits=more headroom, but why would you need all that headroom for a single drum...maybe for a whole mix?
I heard with 44.1 you can have up to 22khz...with 48 you could have 24khz...but cant humans only hear up to 20 khz :confused: ?So why do people mixdown to 48khz or even 96khz?
Will I really notice a difference if I sample higher than 16 bit 44.1 khz?
Go 24 bit. It doesn't give you headroom as much as it pushes the noise floor down farther (48db farther). 44.1k is fine. Without trying to start a fight, it is always better to start out at your target sample rate. The bad effects of sample rate conversion far outweigh the good effects recording at 48k. If you are thinking of selling these, I wouldn't go with really high sample rates because that might cause problems for some people.
