Drum mics
  • Thread starter Thread starter arCHI
A
arCHI
I am just going to hi-jack this thread for my probably very stupid question...
when recording drums is it necessary to send the mics through a preamp? I see lots of info on where to put the mics, what type of mics to use, etc. but can't seem to figure this out.
/n00bishness.
No, not okay to hijack another thread, just start your own. I moved this to its own thread in the drum forum.
Yes, all mics need pre-amps. Some pre-amps are built into the mic, some are built into a mixer or interface and then you have standalone pre-amps.
duly noted.
thanks for the info. as you can tell, i havent actually started recording yet, but am curious about starting and trying to take an inventory of what i will need.
duly noted.
First thing you need is drums. Second, the ability to play them or find someone that can. Third, a decent room to record them in. Fourth, mics. Fifth, pre-amps.
^ Yes, I realize I am getting way ahead of myself, but I am trying to answer some nagging questions before I begin.
So, I just discovered I can only run 2 tracks into my recording device (Lambda Lexicon, in this thread). What approach would you recommend for recording the drums?
1) Single room mic
2) 2 overhead mics in stereo
3) 2 overheads, 1 kick, 1 snare mixed on a console and recorded in stereo
1) Single room mic
4) EZDrummer
I'd pick 4.
Seriously, considering that you want to use a 2 channel interface, you should consider a VSTi instead.
Depending on the music, and the mics you decide on (as well as all of the other variables Greg mentioned above) you could feasibly get a workable drum track out of any of those available options...
Two quality LDC overheads could produce a surprisingly good stereo mix for you.
Four mics (Recorderman or Glyn Johns) into a mixer may give you more control.
Just don't skimp... You're not going to get the sound you want into your computer if it's not being made in in the room.
Of course, another option would be to add a 4 or 8 channel interface into your budget...
:rolleyes:
yes, that may very well be what i end up doing. just trying to see how much use i can squeeze out of what i have before i commit to something more.
thank you all very much for the advice!
You're not gonna be happy with 2 mics on the drums if you're playing anything more rocking than indie-ish singer/songwriter crap or folk music. You can get nice drum recordings from 2 mics, but it won't hold up in a rock mix.
i kinda liked the four mics mixed on a board and set to the interface as a
stereo mix.. on a budget, that could get a good mix. spend the money on
some good overheads, once the drum tracks are down, i rarely record more
than two tracks at a time
