It's worth it's weight in Gold (or, uh, diamond-crusted platinum)...
Before I post all this Machinedrum hype, I gotta say that I own an 808, 909, 606 drumatix, hr/sr-16 (both the grey one & the black one), Linn Drum, a few different Boss Dr. Rhythm things, a weird-assed Russian drum module, RS7000 (nice drums & perc, fantastic tweakability) and a few other drum machines I'm too lazy to mention. That being said, If I could only have one, the Machinedrum would be it. There are a few other drum synths I plan to buy as the crow flies, but I believe that I'll continue to run into some redundancy issues as my Elektron can be made to stink like shit or shine like the sun if I want it to.
By the way, Moeses, if you really dig that Sequential box, you should check this machine out, as it can really churn out sounds just like the original. I even use it instead of
my Linn drum sometimes due to it's functionality & kick ass sequencer (plus CC programmability with sounds & fx)...
Anyway, here's some of the press blurbs (all true, too!)
4 drum synths in one box...
TRX - TRX is inspired by the classic rhythm machines of Rolands TR-series. Compared to its timeless forerunners TRX brings an extended parameter set, allowing superior control over the sounds produced.
EFM - Exploring the boundaries of interfering frequencies, EFM is the most extreme of the MD-synths. Examine the EFM-parameters to discover a wealth of new cool percussive sounds.
E12 - E12 carries the noble traditions of sample based drum machines such as Simmons and
Emu SP1200. Built on carefully processed percussion sounds and offering individual control for all E12-machines.
PI - PI is aware of the physical laws of percussion. Having their roots in scientific models, PI-machines are "Physically Informed", but allows you to change the laws of nature.
Effects
SPS-1 offers a dedicated Track Effect System for each of the 16 tracks of MD synthesis. The Track Effects are always at hand with assigned direct controllers. These effects forms a natural extension of the MD-synths and are available to shape the definite percussion sounds. The Track Effect parameters are saved in Kits and can be controlled by the Percussion Sequencer, just like MD-synth parameters.
The Track Effects consists of five concurrent effects: Amplitude Modulation, 1-band EQ, 24-dB Lo/Band/Hi-pass Resonant Filter, Sample Rate Reduction and Distortion.
The Stereo Master Effect System is composed of the Rhythm Echo delay, the Gate Box reverb, the Dynamix dynamic processor, a Parametric and Hi/Lo-Shelf EQ. The Rhythm Echo and Gate Box Reverb each has dedicated sends from the 16 percussion tracks. The Dynamix processor and the EQ
The LFO-system of Machinedrum is composed of 16 individual dual waveform LFO's, synchronized to the tempo. The LFO's can be routed to any Synthesis, Effects and Routing parameter. process the mixed main out stereo signal. All settings for the Stereo Master Effects are part of the Kit.
Yeah, ok, I'm offa the Machinedrum dick now...
diendolo
