J
jon_SKR
Hey all,
I'm about to have a full album I recorded mastered professionally for the first time. I've heard that you should leave the drum shells a bit loud in the mix so that the mastering engineer has enough to work with. from my own amateur mastering experience it always seems to help to have a lot of drum volume. Since I usually mix through a main mix limiter and compression, I'm not sure how to anticipate what the mastering engineer will be doing to the mix later....
Should I mix through my normal main mix compression and limiter (fairly extreme reduction) then just remove them before mixing down for the mastering engineer? Or,
should I mix without any main mix compression and then just give the drum shells a little bump after I've got it sounding good in anticipation of the mastering engineer's compression?
Any advice would be greatly appreciated!
thanks!
thanks!
