sonusman
Banned
Well, ok not quite like tits, but had to say something clever here.
Ok, here is the deal. Just purchased the Lynx One 24/48 sound card last week. Played around alot with the Digital I/O to see how much better I could hear stuff that was recorded on my Fostex D-5 Dat. Obviously, 24 bits on the output of the card revealed many disturbing things about 16 bit resolution. Could mix better with just having 24 bits D/A converters.
Anyway, I just decided to really give the A/D converters their first run through.
OHMYGODHOLYCOWMOTHERTERESAINHEAVENTHISTHINGSOUNDSLIKEGOD!!!!!!!!!!!!!!!!!!!
Check out the mix at 1.37MB at 192bps encoding with Audio Catalyst.
Here is the deal on the mix. I used the same eq settings, except for a little eq tweek on the rythem guitars as I did on She's So Hetero ( www.echostarstudio.com/She'sSoHetero.MP3 ).
The difference also is that Girlfriend has no mute automation on the Ghost console, no effects at all, and only a few volume changes were made from the She's So Hetero mix. Otherwise, it is the same mix.
I think the difference is stunning to say the least!!! Those extra 8 bits just make it rock.
Before, on 16 bit, when the mix would start getting dense, things mixed back would start to disappear. High frequency response would go out the window. Wholesomeness was unthinkable.
At 24 bits, nothing seems to disappear at all when the mix gets dense. High freq response is still outstanding, and it sounds very wholesome.
Although the song is not mixed yet, I will get around to working on it in the next couple of days, then I will mix it to the DAT, and to the hard drive through the soundcard and post a couple 320kbs 30sec posts. You all can tell me what you think of 24 bit. I think it is definately worth the extra money.
A very excited again,
Ed
Ed
