R
Ronbert
Member
There might only be one other person in the world using the DR-40 but here goes-
Bought mine just before Christmas last year. Have been using it fairly steadily (recording guitar is an occasional hobby - not my day job) with an 8 Gb memory card I put into it upon initial use. Has been working perfectly (+/- operator ignorance)
It came with 2 unbranded 2 Gb cards.
This past weekend I decided to use the 2 Gb cards to carry my tracks back and forth to my computer.
Rather than carrying the recorder.
I could record onto the 2 Gb cards but on ending the recording (press STOP) would get FILE ERROR -PRESS ENTER about 1 in 4 times. After the FILE ERROR - PRESS ENTER message I'd press ENTER and the unit wouldn't be usable until I power cycled it (and it took a noticeably longer time to shut off). The recording was still there on powerup so this so far is just an annoyance. There were other instances of WRITE FAILED but I'm not as clear on when they happened.
Symptoms occur on battery or adapter power. Formatting the cards (full format) didn't change the behavior. I've double-checked the write protect tab on the cards is not in the lock position. Internal or external mics make no diference. Seems to occur with files larger than 45 seconds (SECONDS).
This did not , and does not, happen with the 8 Gb card.
I'll probably just buy another 8 or 16 Gb card and consider the issue in the past.
I dropped an email to Tascam support last night asking if they had a run of bad cards.
I'll post their response when I get it.
This post might be useful to someone else someday. It's not the unit.
