dp 24
  • Thread starter Thread starter Randy Perdue
R
Randy Perdue
using this as a mixer have my drum mics hooked to it but the output sound is not loud have amp wide open and of course cutting gain up i get feedbank HELP thanks.
This is going to be tough as it seems English is not your first language.
Someone will be around soon to help you with your issue. :)
What output are you using to get the signal to the amp? I use the monitor output on mine (DP32) and have plenty of headroom. make sure the trim is set correctly on each input and the monitor gain knob is up. you can also use the stereo outs. Hope this helps.
