DP 24 Should I record at 24 bit?
  • Thread starter Thread starter steppingstone
steppingstone
Just powered up my new (latest firmware) DP 24. I don't plan on transferring files to computer. Is there any advantage of recording at 24 bit? Sample rate set to 48k? Thanks. I do have an external cd recorder- if needed.
24-bit, yes. 48kHz, no.
24-bit will increase your fidelity by decreasing noise floor and quantization error on really quiet sources. That means more headroom for you. 48kHz only increases the highest frequency you can capture, and at 44.1kHz that's already theoretically beyond what you can even hear.
Sure, there's a difference, but I wouldn't go to 48 from 44.1. If you want to do this to increase audio quality I'd go to 88.2 if your final project will be an audio CD or mp3. 48 or 96 I'd only use for something that would end up tied to video. I wouldn't record at 48 just to render down to 44.1 if it were me.
24 (or 32) at 48K has worked for me for years, and 48K is more common if you ever do start to use computers more often.
