DP-02 help please
  • Thread starter Thread starter Michael O'Regan
Michael O'Regan
Michael O'Regan
If I plug guitar directly into the console it records fine. However, when switching the input back to line/mic by the switch the mic input doesn't record. I have to switch the unit off and then back on again in order for the input to switch back.
Am I doing something wrong?
-Mike
I am occasionally losing response through input 1 mic/line. I have to flick the switch to guitar and back again to mic/line to bring it back. Its a bit of a pain.
weird
Yeah, that does sound like a pain! :confused:
So, if i have any problems like that then i will post them up here on this same thread... if i find a solution i will let you know.... if i don't even have that same problem then ill let you know.... then.. i guess you could consider it being a manufacturing default???......
Weird
Im not having that problem with my machine. Although i have the DP-02CF. Im guessing you have a manufacturer default?
Hi, thanks for the advice. I'll try the cleaner.
Yep, I haven't used the guitar input for a while - now I'm just spontaneously losing response from Input 1 when using a mic. Sometimes it'll come back on its own, other times I have to flick the switch.
