C
Chaos351
Hi, I'm new here and am no pro of mixing or anything. I'm currently recording a cover of Ozzy Osbourne's "Mr. Crowley" and as I usually do when recording, I double the guitar parts. (Always something I've done, I like the way it sounds in stereo)
The problem I'm having is when I listen to it in mono. The guitars become almost completely washed out. If I listen to it in stereo though, I think it sounds pretty decent. What I'd like to do is have it sound good in both stereo AND mono.
Is there a way to get the parts to not sound like they're phasing when listened to in mono? The only two things I can think of to fix this would be either manually moving each note (Which is something I'd like to not do) or buying Vocalign and seeing if that does the trick for me (Which I'd also like to not do, as it's too expensive for me). Would moving the mic position a little when recording help this? I used different guitars for both parts, I figured maybe their different tonalities would help.
It's not finished, but you can listen to what I've uploaded here: https://soundcloud.com/shaun-clupper/mr-crowley
Thanks for all the help!
