M
moresound
Loud Sun Studios
A friend of mine blew there fuse on a Dr.Z amp. No problem just switch it out tomorrow after picking up a replacement.
Here's the good part .... they put the spring loaded cap back in the fuse holder for safe keeping's
wrong you just can take it off now with out a fuse to push it out once you turn it with a screw driver.
I tried 2 of my best tricks to get it out and the 2nd one finally worked.
1st - screw the cap so as it would normally come out then put a drop of super glue on a pencil then pull it out -nope to tight won't budge glue lets go.
2nd - is the charm in this case I took a wood screw and screwed it right into the plastic cap and with a good tug out it came.
Put the fuse in and was good to go.
Anyone else have good ideas about this goof up and how they would have removed the fuse cap?
