mixaholic said:
thanks pingu for the feedback. so is the linmb pretty much just an upgrade of the c4? so it's better to mix with the linmb too huh?
Its tough on the cpu but itis a better plug.
From the manual
The LinMB is an evolved version of the C4 MultiBand Parametric Processor. If
you are familiar with C4 you will find
the Linear Phase MultiBand very similar,
adding some true breakthrough innovation and technology that yields superior
and purer results.
The LinMB has -
5 discrete bands each with its own gain and dynamics for equalizing,
compressing, expanding or limiting each band separately.
• Linear Phase crossovers allow true transparency when the split is active
but idle. The only effect is pure delay with no coloration of any sort.
• LinMB is equipped with the options for Automatic Makeup and gain Trim.
• Adaptive threshold behavior achieves most effective and transparent
multiband dynamics processing.
• LinMB has the visual interface of the award winning C4 with Waves’
unique DynamicLine™ display showing the actual gain change as an EQ
graph display.
Waves created the LinMB to answer to the most demanding and critical
requirements when Mastering any sound and genre of music.
