SweetDan
I've read many of the suggestions here for getting awesome electric guitar tone, and the overall theme I see is:
1. Record a real amp with a real microphone
2. Make sure the amp is sizzling loud
I tried an experiment tonight while the fam was out - I turned my amp up really loud! And then I recorded it! To make it a truly "scientific" experiment, I also recorded it while it wasn't loud; I left all the other variables constant, though -- same mic placement, same amp settings (other than master vol) same guitar vol/tone settings, same pick, etc.
I've uploaded a file that has both recordings. I can't hear (much) difference between the section that was recorded while the amp was loud and the section recorded while the amp wasn't so loud. (Notes below about the amp/amp-settings, the guitar, the mic.) Can you hear a difference? Which part was the loud one? Which was the soft one?
If you can't hear a difference (other than the fact it was 2 separate performances, so my timing may have been slightly off, or a phrase cut short, whatever), can you explain why? Is my amp too cheap to make a difference? (It's a Vox VT30, 30 watt, 10" speaker combo amp, which came out near the first generation or so of modeling amps, so maybe that explains it?)
Anyway, just trying to see what I can tweak to get better sounds, given the limited resources I have to work with.
Guitar: Tele-style guitar, bridge P/U, vol=100%, tone=100%
Amp: Vox VT30, "UK 80's" mode, gain=50%, vol=50, treble=30, mid=45, bass=40, no f/x; for high volume, master vol. ~ 65%, low vol ~ 25%
Mic: SM57, 1" from grille, on edge of dust cone
Here are the files (one an MP3 for quick download, the other a WAV for the audiophiles; both have the same recording, however); I'll check back over the next few days for your comments, and to finally reveal which section of the recording was recorded "loud", and which was "soft".
- MP3
http://eastofcleveland.com/m/ElectricGuitarTone_vol.wav - WAV
- MP3
