YanKleber
Retired
Do I need to lo-pass, hi-pass and DC process tracks digitally generated such as VST sinthesizers and professionally sampled like Addicive Drums along the mixing?
The common answer these days in here would be to over process every single track you have to death with EQ and compression. There's been an epidemic of shitty advice in here lately from clueless trolls and individuals..
The correct thing to do would be to do what actually needs to be done based on how it sounds and not some preconceived notion of doing things because you think you're supposed to do them.
What are the risks on using the pre-processed AD tracks?+1.
Watch out with Addictive Drums. All the preset kits are very heavily processed.
I usually find a kit I like then take off all the preset compression. Watch for OH/Bus/Master compressors.
Either that or just completely start from scratch.
There is no risk, as long as you like the sound of it. With compression, you can't undo it. So it has to be exactly what you want.
The direct answer to your original question is that it depends. If the signal suffers from dc offset, fix it. If there is too much rumble or general low end, clean it up.
You probably get the idea. Don't go through the hassle of fixing problems that you aren't having. There is nothing inherently wrong with digital files that always needs fixing.
There are three steps to any audio processing
1. listen to what you have
2. Envision what you want it to sound like
3. use whatever processing necessary to turn what you have into what you want.
There is no process that you always need to do. It is always dependent on what you start with.
So basically the digital tracks should be left alone unless there is something really obvious. Did I got it. Correctly?
Makes no sense. ^^
Then you need to explain why it doesn't, else you are just going to distract OP from receiving the help provided.
The OP got all the help he needed in post 1.
He even got a brucie bonus in post 2.
I'm noticing that is a tendency about all of the threads in here which is something that recently has entered my awareness (I'm a new member here), I'm going to consider leaving, because in that case it's not worth spending time here.
If you want to contribute to a friendly community.......
Uh huh? You'll forgive me if I'm not writing all this down.
We don't all have ego fights, you just don't know how to use appropriate audio jargon to describe what you're trying to say. It's the equivalent of telling a car mechanic you need your car fixed and saying "the doo-hickey is squeaking, and the whatsitsbobble is leaking whosywhatsit."
In your head it makes perfect sense, but no one else is going to understand you.
Go look up definitions of basic audio terms so you don't need a translator for us to understand what you're trying to say. Then there won't be any issues understanding you, and no (as you so eloquently put it) "ego fights."
Makes no sense. ^^
