halfred
for under a $1000 for recording acoustic concert grand piano in room with not so great acoustisc (13 x 20 x 8.5 )
Why medium? (Just curious)
beyer MC-930
or the 910's (omni)
About that price and common for piano. But they might be more on the small end.
Elements in that medium to large range can have some quite dramitic frequency response curves. They sound great and really in your face, but there's normally something odd about the results. i.e. That pianists right hand is so much louder than the left. I don't remember it being that way live. It's okay for vocalists, where you can use them based on whether they favor a female or male voice. But you can't always use one mic on both. For piano 88 keys and 7+ octaves those larger elements might prove a bit problematic.
KSM32 mics are used alot nowdays
at 4033
mmmmmmmmmmmmmmmmmm
I had an AT4033a. A really nice mic. But really weak in that tenor/baritone voice. Bass is killer, Alto is killer, Soprano pretty good. Probably not great for piano because of that dip in the EQ response. I sold my 4033 to fund my MR-1000. The 4033a is supposedly cardioid, but from what I can remember, it was more omni than my omni's. Enough so that it took me a while to figure which end was the front. As it was my first XLR type mic. Off axis response was pretty even.
KSM44 or C414 might do piano, but they're probably beyond budget. And still might be quirky.
I'm leaning towards the MKH80xx series. 8040 cardioid, 8020 omni. They address a few of the issues. Detail, low end, noise floor, flat response. Not perfect, and way past that budget. But nice IMO... Or at least a lot of the samples of them are nice.
You might try some ribbons. A pair of FatHead II's might do well for your uses. A bit needy / frail / loads of clean gain / .... because they're ribbons. But a lot of the samples on those are nice.
Pariticularly since I have to distance mic in a crappy room.
I'd try to do something about that. You may get far better results with the mics you already have by doing to some simple acoustic treatment in your room.
If I were in your shoes, I'd rather spend a few hundred on acoustic treatment than dropping a grand on another set of mics.
Now that we've opened up to small diaphragm condensers, if you have some time, I would recommend you pick up a pair of MXL 603 mics (used is fine, as long as they haven't been mutilated by a soldering-iron-hack like me) and send them to "Marik" here on the board for a capsule remachining and electronics overhaul (which could include conversion to use a transformer, although at some point it may go out of budget), and make sure to tell him you want to use the mics for piano, and probably describe the piano, the room, the player, and whatever other information he needs.
He may tell you I'm stoned, and that you should use ribbons, but it'll be a good contact to make, in any event.
