C
cantthinkofname
Active member
i wanted to try one a long time ago but for some reason i never ended up trying it, and now i think i might want one again. if you have tried one or own one what do you think?
Pure SEX Nuff said.
Hi, I've tried several and owned a US Special awhile back.. I loved it and wished I'd not traded it.. Here's what I loved about it..
1) It was lightweight, comfortable..
2) It has one of the best most comforatble necks I'd ever played. The neck also is not finsihed and uses a oil instead of finish. They can get away with this because they also use a Graphite Rod to re-enforce the neck strength. others will disagree, but I also believe it helps with sustain because the neck is stiffer and therefore doesn't vibrate when you strum the instrument as much as a thin neck without the graphite.. This prevents the strings from being robbed of vibrating more, (sustain) and therfore it helps with sustain..
3) The pickups are directly mounted to the body on the US version that I had, whcih helps prevent too much unwanted feedback, and again helps with sustain, harmonics, etc, as the body resonates and sends the vibrations to the pickups better I think..
4) The floyd copy was good enough, although I love the Ibanez floyds the best, but this best thing about the Wolfgangs floyd was that it rested on the body, again allowing for sustain.. All things touch on the Wolfies..
5) The body is little and it seemed the neck was set into the guitar better so it's overall length seemed smaller than most guitars.. Might just have been me, but it was sooooo comfortable to play!
6) The pickups were great I think.. That's a personal issue since it's sound, but I loved them.. They sounded great no matter what I was playing it seemed, but I woudlnt' personally play Jazz with them..
BAD things..
The only bad thing I can think of is that the neck gets a tad dirty on the outside, but you can take really really fine sand paper and clean it,
Also, the guitar is expensive now since they're not made any longer.. If you break a neck or something it's not easy to get parts.. That's really being picky though and you'd really have to be a person that was really hard on gear..
Just my TWo Pennies.. Hope that helped..
Tim
BAD things..
Tim
