noisedude said:
Can someone actually talk me through some facts and numbers? My understanding is that the impedance would at least be less 'mis-matched' ....?
Eh?
Impedance mismatching is much more critical with passive sources, like mics and passive instruments. Active ones suffer as well, but can handle a much wider range of mismatching.
Impedance mismatching has two basic effects. The source may not be able to function right, and the signal becomes more susceptible to capacitive losses from the cable, rolling off the high end.
Outputs and inputs both have impedance.
The idea is low output impedance into high input impedance gives the best signal, with no frequency loss from the source, and minimal effects from the cable.
The common standard is input impedance should be around 10X output impedance.
Typical mic- 150-300ohms output impedance
Typical mic pre- 1500-3000ohms input impedance
Typical passive instrument- 7,000-125,000 ohms output impedance
Typical amp input- 250,000- 1 megohm (one million)
Typical line-level output- 1000ohms
Typical line-level input- 10,000ohms
Even if proper impedance matching is followed, the higher the impedance the circuit operates at, the more susceptible to capacitive cable losses it is. That's why you need to keep guitar cables short and of low capacitance, even if the impedance is right, but you can run hundreds of feet of mic or line cable with no problems.
Active sources are generally lower-impedance, and they can interface with more types of gear without help. Whether or not you need a DI for your active bass will depend on it's output impedance.
Passive sources also need the proper input impedance to work right. Mics and passive guitars, for example, will put out a crappy signal if plugged into an impedance that is mismatched too much, in addition to the cable losses. Active sources don't suffer this way as much, but a severe mismatch either way will still cause sonic issues.
Passive DIs have limited input impedance, and so may not be enough for a passive instrument, but will be fine for most active ones.
And, of course, your ears are the final word.
