I don't think so Hepme. I'm not particularly familiar with the 1180, but if your standalone works like most of them, the RCA line in jacks are for a CD or cassette player, and are looking for -10dBV, a consumer level line in. The +4 dBU output from your pre will probably clip the crap out of them. Most standalones have variable impedence 1/4" jacks so as you turn up the channel input volume, it gradually switches from a line level input to a mic level input. The 1/4" jacks are designed so they can accept a balanced TRS line or an unbalanced TS mic cable. Use a balanced out from your pre, either XLR or 1/4" TRS, depending on the outs on your pre, to a 1/4" TRS on the 1180. Turn the channel input volume to zero (line level), and then crank the pre a little until you get enough signal. If that doesn't run hot enough, you can increase the channel input volume on the 1180 just a little, until the two units match up. Hope that helps.-Richie
