DMP3 level question
  • Thread starter Thread starter famous beagle
famous beagle
famous beagle
Ok I broke down and bought a DMP3 as an upgrade over my Behri mixer pres. I'm recording into a Yamaha AW16G.
Here's my thing:
I'll set a good level on the DMP3, where the peaks are just under the red.
But when I then set the level on the Yamaha, I'm already just about redlining, even with the input trim backed off all the way. So I end up having to back the level off on the DMP3 in order to get a safe level on the Yamaha.
Is this a problem? Am I comprising sound quality by not using all of the DMP3's range?
thanks
you'll be fine, nothing wrong with useing less gain on your pre, just means less noise from said pre
(though the dmp3 is relitively quiet)
The meters on the DMP3 are useless, IMO. I don't look at them for anything.
The inputs in my soundcard clip before my DMP3 too. Don't worry.
Yep. What they said.
Listen to your ears and don't start with the meters. After a while you'll be able to translate a cranky meter, but you'll never translate a cranky mix. Ears first, always.
BTW I am a prettymuchnewbie and have a DMP3 - the thing rocks. I use it for all kinds of stuff.
