DM5 - Own Samples?
  • Thread starter Thread starter ndk
N
ndk
Hey there iam planning to buy a DM5 Pro Kit with the DM5 Drum Module.
Is it possible to put own samples on this drumpad or do i need a sampler to realize this? for example: i want to put some real electro samples on the pads.
You can not add samples to the DM5. I think you can with the DM-Pro, but you would have to find a used one.
What you can do with the DM5 Pro Kit, is use the triggers to create MIDI data and send it to your DAW and use a computer based sampler to get you the sampled sounds you want.
I have the dm5 pro kit and I use it to run EZ Drummer in Sonar 6. Sounds awesome plus I get to fix all my screw ups after the fact in the midi editor:)
thanks for the answers. what do you mean with buying a "used dm pro" ?!?
is it not longer produced?!
