Darius Boone said:
How would you loop something on vinyl?
- Darius Boone
By hand. 2 copies of the same record on two turntables.
If I were in your situation, especially given your budget, performance needs, and format flexibility, I'd by this stuff:
1 solid performance turntable - $200.00-$350.00 (doesn't have to be a 1200 or TTX1 or st-150 or any other top-of-the-line for acceptable scratch stability & torque)
1 performance ready CD turntable - $400-$650.00
Any ol' bullshit dj mixer from a pawn shop - $50.00
1 good needle - $85.00
or
1 decent pair of needles - $65.00
This can come to a bit under or just a bit over your $1000.00 budget.
As for exactly which pieces of gear, that'll depend on a more specific look at your possible needs.
The reason I'm suggesting a 1 vinyl turntable & 1 cd turntable is so you can play wax & CDs. If both units aren't the same size (small table top cd unit + turntable), then just switch them around so you develop solid skills with both hands on either unit. If you get to play somewhere that has 2 turntables, you'll be fine.
I like these 2 to play with:
turntable:
http://shopping.netsuite.com/s.nl/c.ACCT106601/sc.2/category.44/it.A/id.2190/.f
---> I know these can take the weight because a kid I know has a pair and I play on them when we hook up. They really work quite fine. Just make sure you got something under the slipmats to reduce friction (for speedier backcueing and less pressure on the platter when you're scratching). You can certainly upgrade this model, but it's still decent, in my opinion.
Next time i'm out I can check some other less expensive tables out and tell you which ones I like, but I already know I like the one above.
CD turntable: Numark CDX - $650.00
http://numark.com/
I like this because:
1.it's the same size as a turntable,
2.has a real piece of wax on top so it feels just like spinning a record,
3.will keep your manual dexterity development in order and encourage ambidexterity, even though you'd be spinning with two different formats - way cool. You can switch the units from one side of your setup to the other if in the beginning one hand seems to be "stronger" or offers you more control than the other. That way you can still get loose with whichever format you need to, and it's way doper to use both hands to rip shit up than to cross them over unless it's for a trick or something. One-handed djs suck.
As you get more experience, you can decide if you'd rather spin with dual cd units or dual turntables. Pick one, and then you'll have a pair of those, plus 1 of the other format for your "third hand." You'll also have lots of options regarding midi in/out (to communicate with other gear, like a drum machine, seqeuncing software, or sampler) AND you're still multi-format.
If you go this route, you'll be able to apply the same "experience check" to decide on the kind of dj mixer you actually
want to have. How many inputs, how many bands of eq, built-in fx/sampler or not, crossfader technology/feature set, and other shit like that.
Anyway, that's what i might do in your position.
Since you're hella new to djing, take a look at this. I don't necessarily agree with all I saw, but it's a good enough primer to help you out, i think.
http://www.dj-tips-and-tricks.com/
