nate_dennis
Ok, so I'm convinced I want to build a reverb from scratch. I don't know a ton about electronics and if my preliminary research is correct, this should be a simple enough intro to building stuff. However, I have some questions.
1. running two piezo transducer to the output should give me increased volume on the output . . . right?
2. Would I need some sort of amplifier after the reverbs output to get the signal back into my FX loop? If so, would a passive DI box work?
3. If i were to engineer a way to make the driver speaker adjustable distance from the springs, would this increase/decrease my pre time?
Thanks guys.
Thanks guys.
