D
DonaldChang
Banned
What is the best software for dithering that doesn't cause significant damage...so like I can convert a 24/48 file to 24/44.1?
ecktronic said:Dithering is really just a way of smoothing out the bits. I might be wrong here but I think dither adds lo level distortion.
Add dither to your master out at bounce stage and bounce to multiple mono rather that stereo interleaved. Then dither each mono track, and keep the track as multiple mono until it is ready to go onto CD at 16bit.
This is from the Digi design Pro Tools course. They say that bouncing to multiple mono and dithering each seperately is better than stereo interleaved and then dithering the one stereo track.masteringhouse said:Ecktronic -
Not sure where you're getting your info from but interleaving audio should not affect dithering, it's just a format for storing the audio.
That may be true, but it would mean that Digi has a broken system as it indicates they are applying the same dither to both channels...ecktronic said:This is from the Digi design Pro Tools course. They say that bouncing to multiple mono and dithering each seperately is better than stereo interleaved and then dithering the one stereo track.
I know there prob wont be much noticeable difference but think this is if you really want to get the perfect sound with no errors etc.
Could be wrong but just what i was told.
bigwillz24 said:I still don't understand.
Why would I want to add noise to my signal?
When downsampling, one is reducing the word length; for example from 48 bits to 24bits. When one simply chops off the last 24 bits, that in itself is, by definition, already adding noise to the signal. Dithering adds a random element to that noise that actually "smooths" the harshness of that noise as it is interperted by the human ear.bigwillz24 said:I still don't understand.
masteringhouse said:Spread the fingers of your hand in front of your eyes and look at your computer monitor. Notice how portions are blocked off and not visible? Now start to move your hand quickly back and forth. More of the screen can now be seen. This is kind of the concept behing dithering, adding a bit of noise to toggle the low order bit in order to "trick" the ear into hearing more than just truncating it.
I dont have a link, I knew someone who went on the Digi course and they were told that. Maybe he got his wires crossed.masteringhouse said:Yes please send a link on where Digi has mentioned this. Pro tools has a dithered mixer, so this makes even less sense to me.
bennychico11 said:well, the way dither is added in Pro Tools is on the Master Fader...which is post fader. If you bounce to disk and select convert after bounce, it will play out the audio and pass through the dither process...THEN after it's done, PT will convert the audio to a stereo interleaved file.
masteringhouse said:Benny -
Are you certain of this? It seems that if you insert a dithering plug on the master fader that dithering would be applied at the depth of your choosing and the bounce would simply be taking the digital stream from the main bus. There "shouldn't" be any additional dithering beyond that point.
