lopie said:
if i record at high resolution how do i get it onto cd, for listening
help!
Define high resolution.
If you are recording at higher than 16 bits, you can choose to reduce it to 16 bits when exporting the audio. Choose "16 bit" in the dropdown box in the Export Audio dialogue. Also, you should make sure you have Apply Dither checked in the Options -> Audio -> Advanced menu.
However, be aware that Sonar doesn't have the greatest dithering algorithms, so you might want to export at 24 bits and use a different program (e.g., Wavelab) to dither down to 16 bits.
If you are recording at higher than 44.1 Sample Rate, Sonar will not help you. There is no way to convert sample rate using Sonar. Again, I would suggest a different program (Wavelab would work well here also).
I believe there are also freeware programs available for converting sample rate. Do a google search. However, I really believe you get what you pay for with some of this stuff.
There is also a workaround using Windows to convert the sample rate, but I'll let others comment on that. Personally, that is not the way I'd go.
