J
Jamie1989
Hi all, new to this forum, but I do a lot of home recording and studied it for a year.
Im good with computers and usually can fix problems, but I thought it would be quicker/easier to try here since im sure somone else has had the problem before.
What im using:
Cubase SX 2 + VST instruments (drums moslty but sometimes orchestral)
Windows Vista
M-audio Mobile Pre (USB dual channel)
On-board sound/graphics
Problem:
During recording/playback I'm getting an aweful crackling sound, at first I thought it was clipping, but my input gain is pretty low and the output indicators are not even in the yellow, also when I export an MP3 and play with WMP I get a perfect sound. Sometimes its not so bad but the more tracks I add and the more audio I layer, it gets worse, sometimes its not bad but its getting a bit hard to mix, trying to listen carefully to the levels/eq and all i hear is crackling. I think the problem maybe something to do with hardware. I never got this on my old computer using the same cubase and the same M-audio interface. I also noticed that when I scroll through the project (whilst playing) it crackles as i move the scroll bar, and sometimes other graphical things like playing with the eq graph. Ive been living with it for a while since I can still mix down and export, and the the exported track is fine, it just seems to be getting worse, and mixing is becoming hard.
Any suggestions?
cheers,
Jamie
What im using:
Windows Vista
Problem:
Any suggestions?
cheers,
Jamie
