cordura21
The manual says (page 30 of 'Getting Started with Digi 001'):
"Main Analog Outputs
....These outputs are balanced, +4 dBu line level
Analog Outputs 3-8
...These outputs are unbalanced, -10 dBu line level
Monitor Outpus
These outputs can be connected to powered speakers, a stereo power amp, or another stereo destination to monitor your mix. The monitor outputs play the audio that is routed to analog outputs 1 and 2. Analog output 1 material is routed to the left monitor output, and analog output 2 material is routed to the right monitor output. These analog outputs feature 24-bit digital-to-analog converters. You can control the output level of the monitor outputs with the Monitor Volume control. These connectors are balanced, 1/4" jacks."
From what I understand, the common voltage levels on audio equipment are +4 dBu and -10 dBV. Could it be that this machine has some -10dBu outputs, or do you think is am error in the manual?
Also, from the description of the Monitor Outputs, you can't tell what is the operational level of these. Does anybody know for sure?
Cheers, Andrés
Analog Outputs 3-8
Monitor Outpus
Cheers, Andrés
