miroslav
Cosmic Cowboy
Getting ready to order materials for my DIY acoustic panels, but I also want to add some diffusers at least on my back wall.
While I do know the differences between the basic types of diffusers (QRD, Skyline, Fractal, etc), and how they work and how to determine which frequency range the will affect...I can't find any real info if there is a preference for one type or the other when used in a larger space....?
The most info I find about the size of the room relative to diffuser use, is that diffusers are not recommended for small rooms, where listening positions are going to end up too close to the diffusers, often resulting in skewed acoustics because the different frequencies don't have enough room to diffuse, so you can get comb filtering effects, etc.
OK...but there is never any mention that for a large room or given listening distance...that one type of diffuser is better over another.
So in my case, my front and back walls are about 25' apart...and my listening position will probably be around 6'-8' from the front wall (I still haven't placed my console or monitors in the room for exact distance).
I'm most likely going to go with the QRD diffusers...but I was curious if anyone know of specific info about diffuser selection relative to the room size?
Most of the info I found is about the frequencies affected depending on diffuser depth/design...on diffuser placement...and also on the type of dispersion (horizontal, vertical, 1D 2D..etc.)
I really do love "the look" of the fractal diffusers...but they appear to be much more involved to build. The QRD seem to be the easiest to build if you want a good sized diffuser that has very known/specific math and usage...with the skyline probably the simplest AFA materials and building process, but probably more time consuming if you want to build larger ones.
