dobro
Tonight I tested some mics. I recorded the same guitar piece three times using three different mics (Shure SM-57, AKG C-1000, Rode NT-1), and then the same vocal piece three times with the same mics. Then I sat back with a beer and listened to the tracks a few times.
As you'd expect, there was greater detail as I went through the series of mics. However, I'm thinking the sensitivity of the mic you use is a bit like an effect - you pick and choose which one you want for the job, you don't automatically reach for the most expensive (most sensitive) one every time.
Also, the best performance I put in tonight happened to be with the AKG, not the Rode. The track *sounds* better, although recorded on a less sensitive mic, because the playing and singing was better. Performance supersedes technique/technology every time.
This post contains two different issues.
