A
amentiz
What is the difference between balanced and unbalanced inputs and outputs?
amentiz said:What is the difference between balanced and unbalanced inputs and outputs?
Blue Bear Sound said:Balancing/unbalancing has less to do with cables and more to do with a way of passing a signal while minimizing noise introduced to the signal as it travels thru the wire.
"Balanced cable" is a misnomer - because it isn't the cable that "balances" a signal. To run balanced signals though, REQUIRES 2-conductor cable, although the mechanism for balancing is at the sending and receiving ends of the gear and not the cable itself.
Single conductor cable - has only two wires, one hot and one shield. 2-conductor cable has three wires, one positive, one negative, one shield.
A cable having TS connectors is a single-conductor, and a cable having TRS connectors is a 2-conductor cable that can be used to run balanced signals, or 2 channels of unbalanced signals (such as for headphones!)
Hope this clears up the confusion....
BINGO!!!KevinTran said:So you really gotta know your gear and the chain they're in.
Correct....detuned6 said:1. using unbalanced TS cables makes the line unbal, ?
Also correct....!detuned6 said:2. say im using TRS cables (pre to sound card) and i put a RNC(unbal) between the the two this makes the line unbal, so there is no need in using TRS cables if the line isnt really balanced from start to finish ?
Theoretically, yes - but if you're not having a noise problem now, then you won't see much difference (except that you're losing about 6dB of signal by using the TS with a balanced signal - because you're chopping-off half the signal), so you'd gain the 6dB back...detuned6 said:If thats the case, i would be better off getting a preamp that had a unbalnced insert to input the RNC in so i could use TRS from pres to digi 001.(and keep it balanced at +4)
No... balancing occurs on a single chain.... a 24-channel mixer has 24 "chains" that are independent. You can have one channel running balanced and the one next to it unbalanced. The main outs are yet another separate "chain"...KevinTran said:And if you have a 23 Balanced signals going into your 24-channel mixer, and the last one is unbalanced, then the output from the mains are going to be unbalanced?
kt
It's not that you get more gain - it's that you restore the gain you lost running a balanced signal via unbalanced cable!detuned6 said:Shit, 6db of gain!, im not having any noise problems. So let me get this clear, if i use a balanced cable (as opposed to the unbalanced im using now) i will get 6 db more of gain going into my digi 001?
