Difference 25.5 vs 24.75 Scale Length
  • Thread starter Thread starter pepsiguy
P
pepsiguy
Does anyone know the primary difference in terms of sound, feel, etc between two guitars with different scale lengths. Strats are the standard example of a 25.5" and a Les Paul represents the 24.75". There are other significant differences between these two guitars, wood, weight and most importantly pickups.
What does the scale length difference affect?
Thanks,
A longer string needs to be tighter to reach the same pitch. A tighter string will have a sharper tone, and, obviously, require more pressure to fret or bend. It's about like the difference in tuning up or down about a step, less than a string gauge change, IMO.
A longer scale length also makes stretches harder, but then it's ever so slightly easier to play higher frets.
I've always wondered this as well . . .
Good question. Thanks for the responses.
Some modern guitar makers, notably PRS, make guitars with a 25" scale length. I think it's a nice compromise.
Technically true, but the difference is miniscule. According to my IIRC calculations, the difference at the fist fret is about 0.04 inch, a good bit less than 1/16. It is not so much that you can't play one or the other, but if you develop muscle memory on one, it will cause an imprecision in fretting on the other, IMO YMMV.
I play both, and changing back and forth doesn't bother me in the least.
I also play both, as well as basses from 31"-42" scale and a mandolin that is much smaller. It's not just the single fret difference. A four fret stretch (say, 2-6) is a little more than 1/8" of an inch. It's not huge, but I notice the difference quite keenly.
Interesting. Perhaps I use my eyes for reference more than you? I meant to point out the overall difference of a several-fret stretch in my post, but I am too lazy to calculate it. I would still maintain that 1/8 inch is pretty small, dealing with a stretch of around four inches, and the margin for error a fretted instrument provides. Again, IMO YMMV.
I have much more trouble with different body shapes moving the neck back and forth than scale length. If I play my flying V for a while, and switch to a LP, I try to fret at the 12th somewhere around the neck joint.
Same here.
I also think the longer scale is better for high fret playing.
Sonically, the primary difference is in the degree of articulation, and in how well the notes blend together. I like to say, a short scale guitar sounds a bit more like a choir singing together. A long scale guitars sounds more like a group of soloists singing at the same time. Both are good, even fantastic. But they are different. Personally, I like to have guitars with both so I can use which ever sounds best.
Oh, and for all that all of Gibson's guitars usually get lumped into the 24.75 inch scale length (excepting those which are shorter, of course), the Les Paul is actually 24.65 inches. Gibson has used a whole BUNCH of scale lengths of "about 24 3/7" over the years, some more acurate, some less. You can frequently put two guitars of the same model from the same year side by side, and see as much as a 1/16th of an inch difference between some of the frets, which is HUGE for fret possitions.
The most common scale lengths are:
24.65/24.75/etc - on Gibsons, mostly
25.4 - Martin long scale
24.9 - Martin short scale
25 - PRS
25.5 - Most Fenders, Strats and Teles, though some of the other guitars used a shorter scale.
Light
"Cowards can never be moral."
M.K. Gandhi
How can you measure the scale length of a guitar? Since the bridge saddles are different distances away from the nut, i'm not sure what to measure to.
I agree with that too; I wonder how much of that is the Fender vs. Gibson construction other than the scale length? I've never played a set neck magohany body humbucker 25.5", but maybe you have some thoughts on that?
Well, it is not just Strats and Les Pauls that have different scale lengths. Martins have a longer scale length than Gibson acoustics, and the same thing is true there. I've done the same model of guitars with both, and it holds true.
Light
M.K. Gandhi
While scale length makes a difference, I find the difference of width and thickness of the neck make a greater difference in the comfort of playing. Neck sizes and shapes vary almost as much as hand sizes. I say find what feels right to you.
If you intend to do any detuning a longer scale is better.
Light
M.K. Gandhi
Most Gibson acoustics.....my J 200 is 25 1/2.
I don't notice it much with electrics but there is a difference in feel with the shorter scales like J-45 R. It's not a bad thing, just noticable.
