FZfile
Ok
Now I'm starting to get a little bit pissed at this Franken-piece-o-crap project of mine.
I went back to the baord, so to speak, after getting a "floppy failed (40)" error message and took the drives out and started from (almost) scratch.
I have an AMD K6-2 533 but it was only reading 233 (besides the floppy error).
I was asked if I had set the jumpers for the buss speed and voltage (NO!!) and if the light on the front of the floppy STAYED on (YES!!).
I was told to flip the floppy cable around so that the red stripe was on pin 1 and to set the jumpers.
....which I did.
I also made sure all of the device (drive) jumpers were set correctly and rearranged the placement of everything so it was more logical and neat in the case.
Put it back together......plug it in.......N O T H I N G ! ! ! ! !
What the f*#&???
the power supply now does nothing.
Well....the screen makes a very faint flicker.....and then nothing.
It just worked (incorrectly) last night.
I thought it was a short in the switch, played with that, nothing.
Tried different power cabel.
tried plugging it into a different socket (in another room)
NADA
ZIP
Completely stumped.
Its not that I absolutely WONT buy a new PS but the freaking thing JUST worked and all I did was unplug it and change some jumpers on the mother board.
H E L P !!!!
Also there is a setting for 112mHz CPU buss clock and 112mHz SDRAM clock speed (as well as 100/100 and below).
What is that about????
The ratio settings are up through 5.0x and 5.5x so the could set the chip to run at 616???????????
I set it for 100/100 at a 5.5x ratio so I guess i would be overclocking by 17mHz (at 550). I assume that is no big deal. I have a burly hs/fan (new one).
...that is, no big deal if the frigging thing had any juice.
Is there some kind of tripper or internal breaker that might have triped?????
Somebody please shoot me.
I just want to make pretty looking sounds.
-mike
....which I did.
What the f*#&???
NADA
ZIP
Completely stumped.
H E L P !!!!
-mike
