M
mixsit
We were wondering about combining bus outs, level and clipping and such in the other post, so just to find out for sure...
Recorded 2 tracks of 200hz sine wave at -2 db.
Assigned each to a separate v-main, both v-mains to the same out, spdif s1/2 to the Waves L2.
With one bus on (bus set at zero), all meters (track, bus and L2 box), line up at exactly -2.
With both buses on, all show O/L.
Set both v-mains at -4.4 db, L2 meter shows -.5db, all ACKUS just under zero.
Export both buses to a single wav file (Thank you Cominginsecond!
), import to new track (assigned to third bus, track and bus set 'zero'). Solo new track, all meters show -.5db again, waveform nice and round just less than a full track display.
Same export/import to a fourth track, but with both send buses levels set at -4.0db -all meters show O/L, waveform shows slight flattening off the tops.
Frankly, I can't imagine needing any more precision than this.
Dobro had a post a while back where he asked why a small eq cut on a near-max track caused the track to go ABOVE zero. I tried UltraFunk and Timeworks (clean and vintage) on the -.5db track, but found no increase like he did FWIW.
Wayne
), import to new track (assigned to third bus, track and bus set 'zero'). Solo new track, all meters show -.5db again, waveform nice and round just less than a full track display.Same export/import to a fourth track, but with both send buses levels set at -4.0db -all meters show O/L, waveform shows slight flattening off the tops.
Wayne
