rayc
retroreprobate
I record in a downstairs room. It's 3.6m x 3.4m & 2.45m high.
Two sides are external walls (gyprock then 1 thickness brick) the other two are internal gyprock walls - one against a small corridor and the other has a sitting room on the other side. Directly upstairs is a bedroom.
Along one of the external walls is a window almost the entire horizantal length and about 1/2 the vertical height.
Apart from a wall length book case full of a wide variety of sizes of books on the wall opposite the window, very heavy drapes at the windows and almost all surfaces covered/cluttered with "stuff" there's no treatment in the room.
When I play/playback loudly I note that after a couple of minutes a slowly thrumming bass sound develops. When all music is stopped the thrumming continues for several minutes and sometimes even longer.
I did a freq test (downloaded from real traps) that gives some interesting info about the room's problems but doesn't indicate the thrumming (the test doesn't present longish periods of a wide range of freqs all at once).
I know I need bass traps & I a cloud for standing waves to assist in the monitoring position. However, I'm perplexed by the bass hanging around. I can sometimes come downstairs 5 minutes laters & it's still there albeit somewhat reduced and fading.
Any ideas?
Any ideas?
