RecordingMaster
A Sarcastic Statement
Here's the DI box I currently have, until I can invest in a superior one.
It's a Yorkville YDI-1P Passive DI Box with a jack to receive signal from the guitar, a jack to send the signal to the guitar amplifier, and an XLR jack to send the signal to the board.
I have two scenarios and I want to know if I am doing this right...
1) When I record a guitar track (standard electric guitar with passive pickups) and wanted a miked track as well as a feed from the DI, I plug the guitar into the "From Instrument" jack, I run a musical instrument patch cable from the "To Amplifier" jack to the guitar amp, I mic the amp, and lastly I run an XLR cable from the "To PA Board" jack on the DI box into an XLR jack on my snake.
In the control room, I take the receiving XLR end of the feed from the DI, add an XLR to 1/4" TRS adapter, and then into a High Z jack on one of my outboard pre-amps (or into my interface with the "guitar" button switch in on that input).
Is this correct, or is the DI box converting the signal into a signal level that should not go into a Hi Z jack? In otherwords, even for passive guitar pickups, should I be plugging the XLR connection into an XLR mic jack on one of pre-amps?
2) When I record an electric guitar or bass that has active pickups, I do all the same as above, except I remove the XLR to 1/4" TRS adapter on the recieving XLR end of the feed from the DI, and plug it into an XLR input on one of my pre's.
I am assuming that this scenario #2 is at least correct?
Last question sort of unrelated but not really...If I want to re-amp a raw guitar DI track back into a real guitar amp, what are the step-by-step connections to use my DI in reverse?
Is this correct?: 1/4" TRS cable from interface output with DAW track level at unity gain, add a 1/4" TRS to XLR adapter, then into the XLR jack on DI. Then a standard instrument cable from the "To amplifier" jack on the DI box into the amp, then re-mic the cab.
Sorry about the long post, I didn't want to leave out any details.
Your help is greatly appreciated as I'm no electrician, nor guitar tech! Thanks!
