Derek Heffernan - Get Motivated
  • Thread starter Thread starter Life Rise
Where´s the lows? Sounds thin.
Try an eq around 70 HZ, wide "Q" (not less than 12 db boost).
Ciro
If this song had a chorus, it would be great. Not bad at all. The mix as someone already mentioned is a little thin. You could even fill it out with a bass guitar. The horns got a little old after a while, and your accent was humourous at some points, especially in the beginning when your talking about procrastinating, but I think you can use it to your advantage and set you apart if done properly. Nice job!
Cheers onestu, it was meant to be a little humurous more because of the lyrics than the accent tho lol. Thanks for checkin.
E
Replies
7
Views
829
UltimateOutsidr
UltimateOutsidr
subvibe
Replies
1
Views
334
K-dub
K
