D
Don Lee
And a good evening to all....
I've been dealing with a problem in 98se with Delta 66/SB Live and Sonar where when both the Delta and SB Live are enabled the Delta doesn't "show up" in Sonar. Of course, if I disable the SB Live the Delta shows up just fine. And note: there does not *appear* to be any IRQ conflict. Several folks have been kind enough to respond, and it seems like a bunch of people run the same config, but I've yet to find the answer to my problem. I have noticed that the SB Live is using WDM drivers....are there Delta WDM drivers that work in 98se? Which release?
Is the answer XP? I can do that. Is the answer that both cards need to use WDM drivers? I just want to use both cards!
