Delta series converter question?
  • Thread starter Thread starter formerlyfzfile
formerlyfzfile
formerlyfzfile
I know this has probably been covered before but...
Does the Delta 1010 LT have the same (lesser) converters as the 44 and 66???
Do you have to jump to the full 1010 for better converters???
Basicall I'm running a 44 now and need to get an 8x8 set up (or at least a 6x12 ...looking at adding a delta 410 cuz there soo cheap.) and was condering adding another 44 instead of a 1010LT because of the balanced connections on the 44.
But i can get a 1010LT for pretty cheap.
I know the obvious thing is to just get a real 1010....but I cant swing it now cuz I'm also trying to muster up flow for a Da-88 for my portable rig.
Any thoughts??
-mike
The 1010 has better converters. Not sure if the 1010LT are the same as 44/66 but the specs look close. There are people around here using the LT and like it. I think it would be just fine. But yeah if you want to make a step up you will need a 1010.
Don't know about their suppport or anything but have you checked out the Terratec Phase 88?
