Delta logic question
  • Thread starter Thread starter 47ronin
47ronin
This is probably a stupid question. Ive been working on some songs in delta logic for mac and i want to burn them onto a cd just to listen to them through something other than my monitors....the individual parts of the songs are aiff but the song as a whole is not...ive tried the mix down with the glue button thing but it is still not an aiff.....can someone please help!!
thanks
47ronin
I know jack about macs. but on the PC you have to convert those AIFF files to .wav
then mix all the tracks down to a single stereo track.
Then dither down to 16bit before you can burn
I use Logic on PC and you need to hit the BOUNCE button on the master bus. It will then prompt you for a file name and type. You should be able to select the appropriate format then. It will then digitally bounce all active channels to that file. I only do this on a stereo mixdown file.
How the hell do you record anything on logic delta. I could see a record enable button for the tracks so i bought logic gold.
