D
Dig
I have a delta 44 from M-Audio that is driving me crazy. I have spoken to their tech support but I might as well be speaking to another country.
My system is an AMD 2600+. Win2K, 512MB Ram, 80GB WD & 120GB Maxtor machine.
The problem is the audio card keeps adding clicks and pops into the sound stream. I recorded a concert the other day on a Fostex VF160. When I played it back on the Fostex it was pristine. So I wanted to edit the sound and burned a cd with the waves and imported it into my computer so I can use my CEP.
When I get the files in my system if I just play them using any software (mediaplayer, winamp, etc) there are tons of little clicks and pops. If I change the DMA buffer size it gets a littl better but never goes completely away.
When I put them in CEP the clicks an pops are now part of the file. I edited the file and burned a cd and sure enough there were all the clicks and pops.
M-Audio says it is because the card is sharing and IRQ. So I changed my ACPI to standard and set the card so it does not share and it still clicks and pops.
I then used a brand new drive and installed WinXP and it still clicks and pops. How can anyone use this card to edit with?
Any ideas on how to straighten this out?
I have so many projects to finish I can't waste anymore time.
Thanks
Thanks
