delta 1010's balanced/imbalanced I/O's...???
  • Thread starter Thread starter PRiZ
P
PRiZ
what's this supposed to mean, it just says 8 I/O balanced/unbalanced, how can they be both...? I don't understand, please someone make this clear...
thanks...
Heh, that's just one of those things where its good enough to know that it works. Actually, balanced <-> unbalanced connections usually work, its basically the same as a typical balanced connection, but I believe some gear (like the delta) has the ability to sense and compensate for balancing.
The line levels for balanced and unbalanced are a little different. The Delta Mixer allows you to select which you want; this adjusts the line in levels accordingly. The jacks are TRS for balanced 1/4" TRS plugs, but if you plug in a regular 1/4" unbalanced plug the signal still comes through.
thanks...
As long as I get balanced connections, this is very important I'd assume. I'm calling the seller today to make final arrangements...
I can't find the Event 20/20 bas monitors USED anywhere. I'm starting to think of getting diff monitors...
Less important than you think. As long as you stick to shorter cable runs it is likely that there will be weaker links in your signal chain than any unbalanced connections.
