sloom
Member
I want to use my Tascam M-30 mixer to front-end a recording system. The Delta 1010LT is unbalanced I/O... If I'm going first into a mixer, using it's preamps, and then use the unbalanced 1010LT to go into A/D converters > PC, will my sound suffer? Would I be better served to go for a higher-quality interface, or am I simply now treating my post-mixer signal as any other line-level signal?
This is where the -10dB spec (Delta 1010LT) comes into play, isn't it? I'm thinking it's a headroom issue, and +4 is "what you want". More gain going into the converters. Right? Hotter signal means less signal loss, as long as you don't clip.
Also- I guess the A/D converters on the LT are on the PCI card itself, since there is no break-out box. That might mean noise from the PC?
Can I get a concise, spelled-out confirmation/correction of this conclusion?
Thanks for stooping down.
