M
MBP2112
Howyadoin,
Just thought I'd pass along some system specs that are very promising, and contrast them with my previous DAW PC.
Old system:
AMD AthlonXP 1800+, over clocked to ~2000+, MSI K7N420 Pro (original nForce chipset), 1GB DDR2700, 2 WD JB series drives, Innovatek water-cooling system, Delta 1010 (of course), don't have the driver S/W rev that was on this system. Before the watercooling setup was installed, this system had fans out the wazoo to keep cool, it was a noisy little bugger and ran as hot as 72 deg.C when tracking in a room with an ambient of 32 deg.C.
New system:
Intel 2.4GHz Northwood, which has been successfully overclocked to 3.0GHz, but run at stock speed for this report. I've generated a report via SiSoft Sandra that I'll post at the end of this message showing some of the hardware and configuration details. Sandra is a phenomenal tool for evaluating systems. It would be interesting to see these same details from other successful systems and from those not so successful, to begin to develop an profile for a "best-of-breed" setup for the Delta 1010.
System is built in a rack-mount case with P/S and front-of-case fan, backplane slot case covers removed to help ventilation, 5.25 covers removed for ventilation. This case is going inside a rack mount along with the Delta breakout box, a patchbay, a compressor/limiter and a headphone amp, so I want air to be able to flow through the case to a single 6" fan in the back of the rack, turning slowly to reduce fan noise.
CPU temps without the case mounted in the rack unit are running about 60 deg.C at 3.0GHz, about 56 deg.C at stock speed.
BTW Delta driver on the new system is as follows:
File Name: delta.sys
Library Version: 5.03.00.900
This is the newest beta driver, Delta_29x12_WDM_Beta_Driver.
I've done some preliminary testing on the new system, and the audio quality is excellent, none of the pops and clicks that I'd encountered occasionally on the previous rig. Using a mono -10 unbalanced tape deck input, the noise floor was ~-90dB at 24-bit/96KHz. Electrical conditions here in Muppet Labs are fairly crappy for grounds, and considering the P/S for the Delta and the PC are plugged into outlets on opposite walls, there's no hum to speak of. So far, so good!
Here's an excerpt of the Sandra report:
***** Start of Report *****
<<< General >>>
Done By: MBP
Done On: Wednesday, April 30, 2003
Done At: 11:49:01 PM
<<< System Summary >>>
< System >
< Processor >
Model: Intel(R) Pentium(R) 4 CPU 2.40GHz
Speed: 2.41GHz
Performance Rating: PR2647 (estimated)
Type: Standard
L2 On-board Cache: 512kB ECC Synchronous ATC
< Mainboard >
Bus(es): AGP PCI IMB USB i2c/SMBus
MP Support: No
System BIOS: Award Software, Inc. ASUS P4PE ACPI BIOS
Revision 1002
Mainboard: ASUSTeK Computer INC. P4PE
Chipset: ASUSTeK Computer Inc 82845PE Brookdale Host-
Hub Interface Bridge (B0-step)
Front Side Bus Speed: 4x 134MHz (536MHz data rate)
Total Memory: 512MB DDR-SDRAM
Memory Bus Speed: 2x 168MHz (336MHz data rate)
< Video System >
Monitor/Panel: Samsung SyncMaster 955DF(T)
Adapter: RAGE 128 PRO AGP 4X TMDS (Microsoft
Corporation)
< Physical Storage Devices >
Hard Disk: WDC WD1000JB-00CRA1
Hard Disk: WDC WD400JB-00ENA0
CD-ROM/DVD: ASUS CRW-5224A
< Logical Storage Devices >
System (C
: 37.3GB (34.7GB, 93% Free) (NTFS)
Data (D
: 93.2GB (83.4GB, 90% Free) (NTFS)
New (E
: 488MB (0MB, 0% Free) (CDFS)
< MultiMedia Device(s) >
Device: Standard Game Port
Device: M-Audio Delta 1010
Device: SoundMAX Integrated Digital Audio
< Operating System(s) >
Windows System: Microsoft Windows XP Professional Version
5.01.2600 Service Pack 1
< Network Adapter(s) >
Network Drivers Enabled: Yes
Adapter: ASUSTeK/Broadcom 440x 10/100 Integrated
Controller
<<< Mainboard Information >>>
< Mainboard >
Manufacturer: ASUSTeK Computer INC.
MP Support: No
Model: P4PE
Version: REV 1.xx
Serial Number: xxxxxxxxxxx
System BIOS: 10/28/2002-I845PE/ICH4/IT8708-P4PE
< Chipset >
Model: ASUSTeK Computer Inc 82845PE Brookdale Host-
Maximum FSB Speed / Max Memory:4x 133MHz / 2x 166MHz
IO Queue Depth: 8 request(s)
< Logical/Chipset Memory Banks >
Bank 0: 256MB DDR-SDRAM 8-1-1-1R 6-1-1-1W 2.5-3-3CL
Bank 1: 256MB DDR-SDRAM 8-1-1-1R 6-1-1-1W 2.5-3-3CL
Multiplier: 1.25x
Refresh Rate: 15.60µs
Power Save Mode: No
Fixed Hole Present: No
< Memory Module(s) >
Memory Module 1: Nanya NT5DS16M8AT-6K 512MB 16x(32Mx8) DDR-
SDRAM PC2700U-2533-700 (CL2.5 upto 167MHz)
(CL2 upto 133MHz)
< PCI Bus(es) >
Version: 2.20
Number of Bridges: 2
PCI Bus 0: PCI (1x PCIClk)
PCI Bus 2: PCI (1x PCIClk)
<<< CPU & BIOS Information >>>
<< System BIOS >>
< General Information >
Manufacturer: Award Software, Inc.
Version: ASUS P4PE ACPI BIOS Revision 1002
Date: 10/28/2002
Plug & Play Version: 1.00
SMBIOS/DMI Version: 2.30
(EE)PROM Size: 512kB (4Mbit)
<< Processor 1 >>
< Processor >
Co-Processor (FPU): Built-in
Speed: 2.40GHz
Performance Rating: PR2644 (estimated)
Type: Standard
Package: FC µPGA478
Rated Speed/FSB: 2400MHz / 4x 133MHz
Multiplier: 18x
Generation: 7 (7x86)
Name: P4N (Northwood) Pentium 4 1.6-3.4G 1.5-1.6V
Revision/Stepping: 2 / 7 (9)
Stepping Mask: C1
Core Voltage Rating: 1.550V
< Host Interface(s) >
<< IC Ensemble Inc M Audio Delta-1010 >>
< Device Information >
Device Type: Audio Multimedia Device
Device ID: bus 2, device B, function 0
Windows Device Name: M-Audio Delta 1010
OEM Device Name: IC Ensemble Inc ICE1712 Envy24 Multichannel
Audio Controller
OEM Hardware ID: FUN_0, VEN_1412, DEV_1712, REV_02
Device Name: IC Ensemble Inc M Audio Delta-1010
Product ID: VEN_1412, DEV_D630
Revision: A / 3 (2)
< Power Management Features >
Version: 1.00
Supports Clock Slow-down: Yes
Supports D1 PM State: No
Supports D2 PM State: Yes
Supports PME#: No
Supports PME Clock: No
< Device Capabilities >
Latency Timer: 32 clk
I/O port resources: Yes
Memory resources: No
Bus Master Capable: Yes
Special Cycle Recognition: No
Memory Write & Invalidate: No
VGA Palette Snoop: No
Parity Error Response: No
Address/Data Stepping: No
System Error Line: No
Fast back-to-back Transactions:No
Detects Parity Errors: No
Supports System Error Line: No
Supports Parity Line: No
User Defined Format: No
66MHz Bus Support: No
New Capability List: Yes
Device Select Timing: Medium
Multi-Function Device: No
Header: 00
Interface: 00
< Hardware Resources >
I/O Range: 0000A800
I/O Range: 0000A400
I/O Range: 0000A000
I/O Range: 00009800
Irq. No.: 23
INT Pin: A#
Dynamic Management: Yes
<<< Video System Information >>>
<< Video Adapter >>
<< Primary Display Driver (display) >>
< Video Adapter >
Model: RAGE 128 PRO AGP 4X TMDS (Microsoft
Corporation)
Chipset: Rage128 PRO (AGP 4X)
RAMDAC: Internal DAC (350Mhz)
Video BIOS: BK3.0.2 VR001.001.003.003.000.026 pft3b1^a.
VGA Compatible: No
Total Memory: 32MB (32MB Video)
Texture Memory: 32MB
<<< Sound Card Information >>>
<< Wave Input Devices (Recording) >>
<< M-Audio Delta 1010 Multichannel >>
Device Name: M-Audio Delta 1010 Multichannel
Manufacturer: Microsoft
Version: 5.10
Product ID: 101 / 1
< Specific Wave Information >
Maximum Standard Sampling Bits:16-bit
Maximum Standard Sampling Rate:44.1kHz
Channels: 65535
(Additional devices 1/2, 3/4, etc. removed for clarity.)
<< Wave Output Devices (Playback) >>
Version: 5.10
Product ID: 100 / 1
Channels: 65535
If anyone has any tuning suggestions based on this information please let me know, I'll be happy to guinea-pig 'em for you.
Good luck,
-Mark P.
Old system:
New system:
<<< General >>>
Done By: MBP
< System >
< Processor >
Speed: 2.41GHz
Type: Standard
< Mainboard >
MP Support: No
Revision 1002
< Video System >
Corporation)
System (C
Data (D
New (E
Controller
< Mainboard >
MP Support: No
Model: P4PE
Version: REV 1.xx
< Chipset >
Multiplier: 1.25x
Power Save Mode: No
(CL2 upto 133MHz)
< PCI Bus(es) >
Version: 2.20
<< System BIOS >>
Date: 10/28/2002
<< Processor 1 >>
< Processor >
Speed: 2.40GHz
Type: Standard
Package: FC µPGA478
Multiplier: 18x
Stepping Mask: C1
Audio Controller
Revision: A / 3 (2)
Version: 1.00
Supports PME#: No
Header: 00
Interface: 00
I/O Range: 0000A800
I/O Range: 0000A400
I/O Range: 0000A000
I/O Range: 00009800
Irq. No.: 23
INT Pin: A#
<< Video Adapter >>
< Video Adapter >
Corporation)
VGA Compatible: No
Version: 5.10
Product ID: 101 / 1
Channels: 65535
Version: 5.10
Product ID: 100 / 1
Channels: 65535
Good luck,
-Mark P.
