Decent Multiple In Soundcard w/ MIDI???
  • Thread starter Thread starter scottn5388
scottn5388
Is there a decent soundcard that provides 6 or so audio ins, but also has a MIDI interface built in to it?
I was looking at the Delta 66 but realized it had no MIDI interface. Is there a soundcard that has all of this built in or should I get the Delta 66 and use the MIDI interface on my soundblaster live, can I do that?
I dont have a very big budget...under 400 if possible.
Thanks,
Scott
My C-Port has 8 analog inputs (24/96), 2 digital inputs, and it has MIDI (and the midi jacks are in the breakout box, which is a lot easier to get to). You can find 'em all day long for $450, or around $400 if you look hard enough.
The Delta 66 only has 4 ins/outs, you said you needed six ins right? Maybe check out the Delta 1010LT. It has 10 ins/outs, and also has the MIDI I/O you need. You can get the 1010LT for about $349.99 from www.musiciansfriend.com. I have never used the 1010LT, maybe someone who has used it could post whether or not it's a good card.
Since MIDI isn't going to be synched with audio, it should be perfectly fine for you to use MIDI via your soundblaster.
The Delta 1010 has 8ins and 8outs, plus MIDI, SPDIF, and word clock.
Slackmaster 2000
Thanks everyone for your suggestions....I think Im gonna take a closer look at the Delta 1010LT
Thanks,
Scott
