Great track, love the riffs especially that riff in your second MP3 link at 0:25, can't get it out of my head haha.
Guitar playing is also very tight.
Drums sound a bit too "programmed."
I'm presuming you're using a drum program or samples, but if possible try changing the velocity of each of the notes just a bit, not drastically though. I know in Cubase you can randomize velocities in between values "X" and "Y". I know I myself for the longest time was stuck manually typing in the hit velocity of each note. That might help give the drums a more realistic feel.
Kick and Snare sound weak, I like to start with these values for my metal snares, and then adjust them from there to fit the mix:
Snare
Band 1: 20-50Hz high pass
Band 2: +6-9dB at around 200Hz
Band 3: -7dB at around 800Hz
Band 4: Nice long parametric band boosting +12dB at 20kHz
Give the snare some reverb and adjust the "wet" option while listening to the entire mix.
Download GClip, freeware - (
GVST - GClip) .
Crank the gain to 8-10db, and clip at between 35-45% (just use your ears and watch out for distortion).
Add some light-medium compression and you're set for a massive snare sound.
Always be sure to hit the snare hard, if you're programming the snare try and keep the velocity of the snare around 110-115 to give those BIG hits
More snare starting point EQ and comp. set ups can be found here:
BenVesco.com » Mix Recipes: Snare Drum EQ and Compression
Kick Drum
EQ:
I'm too lazy to type it out... watch this video and subscribe to this dudes channel:
YouTube - Mixing Metal - Kick Drum EQ
Besides that, I find heavily compressing metal kick drums will make them sound SUPER "clicky" so ya... compression is always nice though.
Add some reverb.
And that's pretty much it... then again, I make sure I'm using a good sounding source to begin with.
If your drums kick & snare still sound super crappy after applying these effects then you should probably consider getting new samples for your kick and snare. +1 to msb3671's comment.
Goodluck! This track has lots of potential, would love to hear the final product when it gets there!
- Zac
www.youtube.com/user/scorge120
