undrgrnd studio
OK I need to play drums in my apartment AND I need to sometimes track drums individually because I'm simply not good enough to play a full on complicated reggae beat or something similar. I can play straight blues, rock, or folky music on drums. But when it comes to difficult time signatures, or abrupt changes it really shows that I'm a guitar player and not a drummer. So occasionally I will play only bass and snare. Then I go back an add hi hat and cymbals. Then I go back and do fills. Yeah I know this is a horrible way to get a good drum feel or sound, but I have no choice.
I was thinking my best route would be to use some sort of finger triggered device so that I can sit at my recording PC and use a drum machine of some sort to repeatedly try to get the drums in perfect time to prerecorded full song tracks.
It's way easier for me to play guitar to a click track and then go back and do percussion later, because I'm not good enough to play a song alone all the way through on drums while remembering where all the changes are unless I'm actually playing along with someone..
The Yamaha DD55 is a sort of toy like triggered drum pad set. Although it's pretty cheap in construction, it does have the ability to actually use sticks and foot pedals for more realistic sounding beats. But I'm concerned about pad sensitivity and cheap samples.
A drum machine is another option, but the thing with a drum machine is that they are designed to program drums and I need something that I can play analogue with. Something I can play along with while recording. Can a drum machine be used in this way effectively?
Last choice is one of those controller pads that I always see. The problem here is I don't know anything about using a controller, and I assume I would then also have to buy some sort of software pack that the controller pad synchs to. Then I would have to make sure the software and hardware work with Adobe Audition which is what I use to track and mix with.
Does anybody have any insight into my situation? What did you do? I've been getting complaints from neighbors about using my acoustic drum set, and really it's hard to record yourself doing drums, having to run back and forth from the PC to the drum set.
