Richard Monroe said:
That should be doable. Problem is, I'm not familiar enough with the Lexicon unit or the soundcard.
The Audiophile soundcard has one RCA L/R input and L/R output. It also has S/PDIF input and output. The Lexicon has one XRL in and out, one 1/4" in and out, and one S/PDIF in and out.
Send the dry signal to the sound card by S/PDIF and an analog signal to the Lexicon, and then to the Mackie (we're basically using the mixer for a headphone distribution amp). The DBX will put out the digital and analog signal simultaneously.
So this is how it's done: Mic to dbx, dbx send digital signal to Audiophile soundcard, dbx also send analog signal to Lexicon, Lexicon then add fx to signal and send it to mixer for monitoring. Do I get this right so far?
Plug your headphones into the Mackie. You'll hear the fx, but it never goes to the sound card.
Then would this mean I just hear the wet signal coming out of the Lexicon or a mixture of both wet and dry, depend on how I set the Lexicon? Even so, how would I listen to the music playing on the computer while at the same time listen to what's being recorded? Say that I already have a guitar track on the computer. Now I want to playback that guitar track and record a vocal track. I would want to listen to the guitar track playing while I record the vocal. Does this mean I just send an analog signal from the soundcard to the mixer then? This would mean I can listen to the vocal (being recorded dry) with fx along with the playback guitar track in my computer, right? What about latency problems then?
Now send S/PDIF out to the Lexicon and then back to the Soundcard by S/PDIF, adding whatever FX you want.
I'm lost. So I playback the recorded dry track on the computer, send it to the Lexicon via S/PDIF to add fx, and the Lexicon then send back the added fx signal to the Audiophile via S/PDIF? It makes sense for me, but the problem is that the Audiophile soundcard has only one S/PDIF input. This is already taken by the dbx.
It does, of course, make the Mackie one of the most expensive headphone amps around, but it should work.
Tell me about it. I'm starting to think that my friend gave me some bad advice on what gears to get. With how I want to record (basically just one track at a time), I didn't think I NEEDED to get BOTH the dbx and the Mackie. I think either one would have been perfectly fine for my need. This kind of pisses me off a little...
The simpler way is to get a send and receive cable (1/4" TRS to 2 1/4" TS), and plug it into the insert on the DBX. The 2 TS plugs go to the in and out on the Lexicon, and just track wet. Check the routing options on the Lexicon. There may be a simpler way to do it. Good Luck-Richie
I do intend to do it that way. It is just that I don't know how to get it done. That's why I'm here.
Anyway, I do have all the necessary cables ready to hook up everything. Two Monster S/PDIF cables, two dual-head 1/4" to RCA Monster cables, and two dual-head 1/4" to 1/4" Monster cables. I just need someone to show me the way and I'm on my way to making happy music.
