G
Grandflash13
Ok, I really mean signal flow, but that didn't fit with DAW so well and I was trying to be amusing.
Anyway, currently I am recording onto a Tascam 2488 and then dumping the tracks into my computer to edit and mix. That's just too time consuming and annoying. So I would like to upgrade my equipment.
Basically I am looking for a way to record at least 8 tracks but would like up to 10 if not more at a time. I have been looking at FireWire devices with pre's, A/D converters, Mixers with ADAT out or FireWire outs and all sorts of other combinations.
The problem that keeps coming up is that I keep looking at some "older" mixers with direct outs. I was thinking about getting one and then A/D converters to go to the computer, but if I do that, am I really needing to bother with the mixer? Isn't that basically going to turn the mixer into a string of pre's and not much else?
I was also toying with the idea of bringing the tracks back out, once they are edited, through the mixer and then sending the stereo mix either to a seperate recorder or back into the computer, but would that amount of conversion degrade the signal?
I guess what I'm asking is, what should I really be looking at to get 8-10 tracks at once into the computer? Money is tight, so I will be starting small and then adding more and more as time goes on.
Thanks,
Rob
Thanks,
Rob
