FALKEN
can you daisy chain a furman power conditioner? for say a 20 space rack?
mshilarious said:If you need 12-15 amps, I'd run a 20 amp circuit and get a 20 amp conditioner, rather than run two circuits. More than that, you need two circuits. Don't confuse outlets with circuits; all the outlets in a single room are likely on the same circuit, in that case different outlets buys you nothing.
If you can get by with a single circuit, then instead of two conditioners, get one conditioner and one plane-jane power strip to get all the outlets you need.
NeoMagick said:i agree, it's a very good idea to figure out how many circuits are in the room (most likely one), and what it's breaking point is.
NeoMagick said:i agree, it's a very good idea to figure out how many circuits are in the room (most likely one), and what it's breaking point is. If it's a 20a circuit, and you're also running desk lamps, computers, monitors, amplifiers, /and/ all this gear, you ought to be calculating for 20 amps total, not just whats in the rack. In that case, you can either replace the breaker in the panel (but that may also need a change of wiring, depending on how old your house is), or run an extension cord from another circuit.
However, i differ on opinion in one scenario. If you're fortunate enough to have a 35/40+ amp circuit in the room, or at least a circuit wide enough to give you some headroom with all your gear running, I'd still go with 2 power conditioners in the 20u rack, rather than daisy chain them, or run a johnny bar.
The conditioners also clean the power running to the gear, and a johnny bar (esp. a cheap one) in the line would dirty it up again. Not by much, and it's a little bit of semantics, I know, but in the long run, clean(er) power can arguably save power supplies and transformers from crapping out. Just as you want as few hops as possible in the signal path going from mic to deck, the same applies to the power.
And if I'm gonna invest in $5k or howevermuch worth of gear (or enough to
fill 20u anyway) another $150 or so in a power conditioner to get /all/ of it the cleanest power I can, is beyond a worthwhile investment in my mind.
FALKEN said:pc interface
tube preamp (2)
compressor (2)
reverb (2)
patch bay
eq (3)
furman
outlet 1- the rack, and my reel to reel
outlet 2 - pc, mixer, monitors (the half not connected to the lightswitch)
outlet 3 - amplifier if recording guitars.
outlet 4 - unused. behind the couch.
maybe the outlet connected to the lightswitch is on a different circuit?
SonicAlbert said:Speaking of misinformation, the first thing to get straight is that the Furman PL8 is not a power conditioner. No actual conditioning of power occurs. This is such a common misconception, and it happens in every single thread I've ever read about power conditioning. The unit you are talking about is a power strip. It has EMI rejection and voltage surge protection, but that's about it, and that's not power conditioning. Just to keep that straight.
The thing is, there's probably other stuff on that circuit as well, so if you've got an AC and a vacuum cleaner and a washing machine *and* your studio, then you might find yourself blowing the breakers/fuses if it's all on at once.
mshilarious said:Well due to Furman, that's what conditioning means now. You're probably talking about voltage regulation.
SonicAlbert said:What I've always considered power conditioning is a box that takes the electrical signal and cleans it up, outputting a clean sine wave. I'm sure that's what Furman engineers consider conditioning as well, but their marketing department has muddied up the waters a bit. Furman does make true conditioners as well as the rack strips most people think are conditioners, so Furman the company certainly knows the difference.
xstatic said:Under drastic conditions a power conditioner can DEFINATELY save your gear. Ever seen what happens to 110volt gear when it is plugged into a circuit running 220? I have. The power conditioner was running a rack full of compression and reverbs at a live show. Long story short...... The power conditioner made a lot of noise, sparks, and smoke when it was powered up. None of the gear however did, and all of it worked for the show. I have a feeling that no regular power strip would have stopped that electricl tsunami.
SonicAlbert said:As far as daisy chaining power strips, I see no reason why you can't.
