Da-88
  • Thread starter Thread starter Lou Corio
L
Lou Corio
On my DA-88 I'm not getting any LED signal's on 1-3-5-7 and on 2-4-6-8 I'm getting static or white noise with showing a signal. This is the master machine and I have one slave DA-88. The tapes play fine and the LED's work fine on the slave unit. I disconnected input and output cables and the cable to link the two machines together and tried playing the tape on the master machine and still had the same problem. thank you Lou
How many hours on the head drum? When was the last time the entire tape path was professionally cleaned? A head cleaning tape might get the drum well enough but it won't get everything else. All it takes is a small build up of crud on a guide or the capstan to keep the tape from contacting the drum properly.
